1 - 4 of 4 Posts
Does anyone have knowledge of the installation process for the Toyota Black Powder Coated Laser Cut Grille? Is there any cutting involved or is it simply taking screws loose and unsnapping the middle section away from the outer section?
Short answer. No cutting involved. But, depending on if you get the correct one, or unless the supplier says some is required. Also, if you want to fit it a little differently.
1 - 4 of 4 Posts
