1 - 2 of 2 Posts
As far as I'm aware the Ballistic Wizards come in 0, +14, and +30 offset. Mine are +14.
My original setup was exactly what you're describing- only with +14mm offset. Everything worked good. The only thing you have to watch is make sure they use stick on wheel weights and not the ones that clip on. The clip on ones run the tie rod end and get knocked off.
1 - 2 of 2 Posts
