When I had the stock BFG tires, I did like Ditch said, I aired them up to max 44psi at the rear and 38psi up front. I replaced the tires this past week with the Michelin LTX M/S2 LT275/65/18 tires, they are load range E, I'll be airing them at 50psi rear and 40psi front when towing, we'll see how that goes. So far these Michelin's are a night and day difference from the stock BFG's. The Michelin's ride so much nicer unloaded and not stiff at all. I'm running them at 39psi rear and 36psi front unloaded. Like mentioned above, you may want to replace them stock tires for some D or E rated tires if you're going to tow that heavy.
