1 - 20 of 24 Posts
Well the suspension kit was kind of a PITA for me to install but finally got it done FRONTS ONLY. I plan to install the rear 1" block later after about 3-4k miles. Also installed the wheels and went to the alignment rack.
Put the rear block on, you've got a Cali lean and will really notice it when you put a load in the bed. Looks good though, that's a clean Blue Tundra.
I ran the supreme suspension level spacer only on the front for a while. But like stated above, if you haul or tow any it will get annoying the way the truck sits. I added coach's shackles to get some rake back.
Anyway, I really like the black rims against that dark blue, looks clean man
I agree with mts6175, cali-leans suck balls and you need to bring the back up. Best option is some CB shackles but if money is tight then install the block you already have on hand. You can install the blocks in absolutely no time so no reason not to.
What's your rim offset? Any rubbing?
sweet looking truck!
1 - 20 of 24 Posts
