Just installed supercharger....so my question is do you guys that are supercharged hit your rev limiter really quick if you nail it rolling about 10mph?
Mine will hit a hard limit and just cut out.....
I am running 35" tires and 4.88 gears with no speedo correction....could this be my problem since i'm running such a low gear with my 35s and should be at 37s for these gears? Kinda my guess..
Also does the hyper tech program the ecu or just intercept speed signal and alter?
Wasn't going to run hyper tech at first and actually sold the one I purchased because with my 35s and stock 4.30s my speedo was only off by 1-2mph at 70...but now with the 4.88 it is off by 5-6mph at 70...which blows my mind considering the before gear variance...
So I guess I had a few questions.....thanks
