2017 Tundra double cab short bed. I need a simple step to aid getting into the truck, something like the Carr Hoop step. I want simple, sturdy and easy to install. Small step only for driver would be enough. I would appreciate advice based on your experience. Thanks.
Big fan of Nfab... Solid and true.
Car Wheel Tire Plant Land vehicle
Looks good. Unfortunately they only have full length (for both doors). I'd rather have just driver's step. Thanks.
2020 Tundra TRD Sport, Rough Country lift, N-Fab Podium Steps, Boss HTX-V Plow, Aries Switchback Rak
I have the same N-Fab Podium steps. They are super sturdy and I use them every time I get into my truck. They are aluminum, and well built. I like them best because they are tight up to the cab helping that lifted look (instead of hanging down low and making a lifted truck look stock). I highly recommend them.
Reactions: Thinlizzyfan
I appreciate your input. I'll probably go this route. Am I correct in assuming yours was a direct bolt-up procedure-no drilling required?
Correct. No drilling, in fact my truck had no running boards or bars on it when I bought it yet it had a set of bolts in the holes already. But the N-Fab steps came with all the hardware as well. Everything lined up for a 20 minute install.
Thanks!
