1 - 6 of 6 Posts
Hi there,
New to the forum but I have a question.
I have a new to me 2010 Tundra SR with 255/70/18 stock steel wheels. I need 2 new tires on the front and currently have Cooper Discoverer A/T3's all around. Rear's look is great shape.
I live in NY and want to get the truck ready for snow season. My question is should I replace just the front tires with a new set of Coopers, replace with K02's, or is there any reason other than weight and appearance to upgrade the steelies with an alloy when getting new tires?
I really don't mind the steelies vs. most owners. Just want to make sure that keeping the steelies is worth it.
I mostly use the truck for hauling my adventure motorcycles, and in the winter going up to the ski mountains.
Thanks in advance!
Mani
Appearance is the main thing for upgrading the steel wheels. If I were driving in alot of snow though, I wouldn't spend alot of money on other aftermarket wheels.
I would keep the wheels since you drive in the snow, and dont mind them.
I'm not sure if the coopers or K/O2 are snow rated. I think Duratracks are, and the sumitumo encounter a/t are snow rated. I would get 4 new tires that are rated for sever snow.
Thanks! I was really wondering if the width of the steelies vs aluminum rims matter that much. I have 255/70/18's vs most aluminums are the 275/65/18's.
I'm guessing that it's just a little extra grip with the wider tire? Would that even matter that much?
I'm leaning on going with all new K02's than just replacing the front with new Cooper Discoverer A/T3's/
Thanks!
I'm pretty sure the factory steelies and aluminum are both 18x8 +60 offset.
The different wheels added at port will vary to say 18x9 but with a lower offset like +50.
Yea the aluminum and steel wheels are the same size, they just put a different size tire on. Tires are same height that you reference above, the 275's are just a little wider.
1 - 6 of 6 Posts
