21 - 30 of 30 Posts
Well when you get yours in let me know results if it helps quite a bit on the tundra
Reactions: Surfer J
Discussion Starter · #22 ·
I will post results to show the before and after results of the kit.
· F&@k Y'all, I'm from Texas
The youtube video of the Tundra jumped to 19MPG.
Unplug your battery and reset the ECU and you will see the same gains on your MPG display for a few days.
I hope it works for you. I'd like to see you run it for a month before you start collecting post-install data. I think any gains will be cut by the ECU to make the engine run normal.
I was also told buying premium gas will show no improvement in mpgs, yet since changing I've seen a 2.5 mpg gain. Don't listen to the haters especially with personal experience on your old truck! Sometimes you can't explain things! But shit happens!
Do a you tube search for this. Dateline NBC - HHO
21 - 30 of 30 Posts
