Help me! My 2007 Tundra died then the starter begin spinning and would not quit. I pulled the hood and got my tools to unhook the battery terminal. I found the battery tie down was loose and touching the negative terminal. I removed it but the starter kept going. I had to unhook the negative terminal to get it to quit. I waited awhile rehooked the battery and the starter cranked again. It continues to spin even with the key removed from the ignition. It's setting in the middle of a pasture and I need any help I can get.
"Resident Liberal"
Solenoid is obviously stuck.
Is it engaged and grinding on the flywheel?
If so, put the truck in gear and see what happens.
If not, put a new starter or solenoid on. I don't know if Toyotas have a seperate solenoid or not.
thanks, I'll pull the starter and have it checked. I see you are from Oklahoma. How about coming on over and working on it for me since you are so close. I live in Arnett, OK, right next to Tulsa.:)
