Which service done wrong most likely caused a start hesitation?
  • Spark Plugs
    Votes: 0 0.0%
  • Injection System Flush
    Votes: 0 0.0%
  • Throttle Body Cleaning
    Votes: 1 100.0%
After recent service my truck is intermittently having a hesitation to start. Looking for opinions on what the dealership likely screwed up?
At 192,000km I had dealership replace spark plugs per Toyota maintenance schedule. At same time, they recommended injection system flush & throttle body cleaning. I reluctantly let them do both, although that was probably an unnecessary waste of money.
So, which of those services is most likely to cause a hesitation when starting and what did they screw up?
I'd guess the injection cleaning and there's a small leak. Pump has to build pressure back up in order to start.
Thanks! If I understand correctly, they disconnect the fuels lines and turn off the fuel pump when performing the service. Can you advise on how to detect a small leak? I don’t know where to look for this?
I would rule out spark plugs if engine revs up and idles normally. It could be either of the remaining two. I would take it back demanding a refund.
It does idle and rev normally.
I did take it back and they gave some stupid excuse about throttle body cleaning and supposedly reset the computer. It’s still happening…
They couldn’t even torque the lug nuts correctly, so I’m very concerned about the quality of work they did. Toyota dealership…
Reactions: RCLB Scogan
Longshot, but have you checked your battery terminals?
Doesn’t seem to be a starter/electrical issue as the starter works immediately and has no trouble turning the motor over like normal. The starter is turning the motor over several extra counts before it fires is the issue.
