1 - 13 of 13 Posts
For those of you with bigger tires than came stock, what are you using for a spare tire/wheel? Did you get a 5 wheel set, or are you using a cheap steel wheel, no spare, etc...
Will a 295/70R18 tire fit where the stock spare tire is?
I thought i heard it would fit, never have tried myself though
Reactions: bproffer
I'm waiting for my wheels, tires, and lift to come in. I ordered 6 wheels and tires to have two spares. 35's won't fit under the bed, so I'm putting both of them in the bed. They'll be tied off, standing up, one in each front corner. Eventually I'll have some bed rails fabbed up for a better place to strap them to, but the bed itself will do for now.
F&@k Y'all, I'm from Texas
I had a roofing nail in my OEM tire so the roofing company offered to pay for a new tire. I took the spare tire off and put it on the OEM wheel. Then I had the roofing company buy me a 33" Goodyear AT spare. I think you can squeeze a 35" tire under there.
Most 35" tires are not true 35s. I have a 33" tire in there. I assure you it fits. A 34" should fit. I believe a nominal 35" will fit.
No spare here. I like to live on the wild side. Plus my exhaust would be in the way. I even unbolted the holder it's sitting in my garage.
I have 35" Toyo Open country MT's. I had this same exact question right before installing them. I got a 35" BFG MT (that I got barely used and for a killer price from a friend) to work on the stock steel spare wheel. I have aftermarket wheels so I have to keep a set of stock lugs in the truck in case I ever need to use that spare. I was able to get that back on the truck spare wheel mount no problem. I have an aftermarket exhaust and had enough forethought to have them mount the pipes after I already had that huge ass spare tire under there. Everything works awesome... No issues at all!
My 35"ish BFG AT on my aftmrkt wheel fits in there. It does touch now that I have the Gibson exhaust on it, but I fab up a spacer to get from touching.
1 - 13 of 13 Posts
