2014 1794, recent left rear bumper encounter with stationary object. Had to replace left metal reinforcement support and bumper plastic end cap. Drove truck while waiting for parts. No sonar issues. Received parts, transferred object sensor (box which mounts on reinforcement) and left rear sensor to end cap. Now I'm greeted with following message at startup, "CHECK SONAR SYSTEM, SEE DEALER, with 2 sensor positions (left rear and ctr rear) highlighted.
After a few seconds the display changes to all 5 sensors highlighted with same message.
Hooked up techstream and got U0232 trouble code:
Ran utility with following result:
Following test resulted in BSM outside mirror indicator on right side only, no indicator on left.
Can anyone help me translate this? Do I need to replace the left rear and center rear sensors? I had to remove both of them to replace the left bumper end and reinforcement, the center rear because the bumper cover had to come off to access mounting bolts.
