1 - 9 of 9 Posts
Hey guys....I just recently got my system installed....got the new Pioneer 8500 indash...Jl audio HD750 amp powering 2 JL audio Tw3s....it sounds amazing.:D...only problem I have is the overhead sunglass compartments vibrate a little with the bass....is there some kind of a thin foam pad or something of that nature that I can stick in the sides so when I close the compartment it makes it snug....????:confused:....thanks guys
Mark
sweet man I'll check it out right now....only thing is hopefully its thin enough so I can still close the compartments...
ya thats what I was thinking...just bought some on ebay for 2 bucks...ahahah....i'll let ya know if it works man...
Reactions: TAMUTUNDRA
Speaker foam gasket. It is basically 3m foam tape . I put two pieces on each of my sunglasses holders and it stopped all the rattles. I have a little more sound so it should be perfect for you. if you don't want to see the foam put it on the rubber nubs that are in the top.
Just put the gasket foam on both sides of the compartment.....so far so good...thanks for the tips guys....:D
1 - 9 of 9 Posts
