1 - 12 of 12 Posts
Let me preface this post with, up until this week, I was super impressed with my BAKFlip MX4. Hadn't had a single problem, it didn't leak, it looked great, I would have purchased again.
Unfortunately, we had a little hail storm this week and my MX4 looks like someone hit it about two dozen times with a hammer. The hail wasn't that bad and I would have expected the thing to hold up much better. To top it off there were 4 or 5 other trucks in the same lot I was parked in. All with different brand tonneau covers, none of which had anywhere near the damage.
Just something to think about before you buy. If you live in an area that gets heavy rain or hail, you might want to consider a brand that uses better quality materials. Just my opinion.
Sent from my SM-N950U using Tapatalk
I’ve held off buying a tonneau for this reason and this isn’t the first review that shows excessive damage from BAK compared to the other competitors.
I have yet to see a review of the BAK Revolver X2 or X4 with a hail review. I’m partial to that design as I don’t want the cover to block the rear window. But I need some first hand reviews as to how it will handle the torrential storms that pass through north Texas before I drop $900. I don’t want a cover that’s going to look like the surface of the moon in a minor storm.
Discussion Starter #4
I have to assume they use the same level of poor quality metal in the revolver. Personally, I would stay away from BAK all together. For the money, buy from a company that makes a product that can stand up to hail.
And for the record, the hail here was marble sized. Nothing anywhere near the post above.
This is a good example of why your're better off spending a couple hundred more on the F1 with the FRP exterior.
Vendor
Exactly, or know what you are buying. The MX4 is aluminum, the Extang solid fold 2.0 is not. Not a fair comparison. If you are worried about hail, don't buy aluminum. The Revolver is a complete different beast, it is made of thick aluminum slats that would not dent and is covered by padded vinyl. Again if you are worried about hail, dont buy aluminum, but it is not poor quality materials, it is design.
Thanks
Josh
Svcustoms.com
Discussion Starter #7
Thanks
Josh
Svcustoms.com
I have to respectfully disagree with you. I read several reviews on other aluminum covers, none of which have the same poor resistance to denting that BAK products do. The fact is that they use either low gauge or low quality metal and it shows in how their products hold up. For the money people are spending, they should hold up to light hail, period. What's not fair is that they don't stand behind what they build. Again, just my opinion.
Holy crap, hail up here looks like shaved ice.
How does the rest of the truck look after hail like that?
Vendor
I also respectfully disagree. What other aluminum covers are you speaking of that you reviewed? Also, Bak is not responsible in any way for hail damage. If your truck would have been damaged would you blame Toyota? No! Contact your insurance company, if they won't pay for the cover get better insurance.
Thanks
Josh
Svcustoms.com
Discussion Starter #11
Thanks
Josh
Svcustoms.com
Josh, I bought the first one from you and I'll probably buy the next one from you too. No need to get your panties in a bunch. The point is that the hail wasn't big enough to cause any real damage, but the BAK is destroyed. Their website claims the MX4 is made from "high grade aluminum" and has a 400lb weight limit. But pea sized hail destroyed it? And yes, if my truck was destroyed from pea sized hail like it was made of tinfoil, I would assume that Toyota made low quality vehicles. So would everyone else!
BAK Customer Service
My experience with the company is that they are completely incredible with customer service. My three year old cover started to leak due to a shrinking of the rubber and they replaced the unit with a brand new one, including all new hardware (which had some improvements). It was out of warranty and had zero cost to me, including shipping.
1 - 12 of 12 Posts
