1 - 6 of 6 Posts
Depends on the alarm, when I install an alarm I need to m the lower panel below the steering wheel, all the pieces required to remove the radio the trim below the glove box and the passenger kick panel. That is because there are connections needed a over. Bit it's not hard even if you've never done it the Tundra is a retry easy truck to work on use take your time.
1 - 6 of 6 Posts
