1 - 6 of 6 Posts
OK, so I put a firestik stake antenna mount on the bed, routed the cable thru a convenient hole near the front of the bed, and then removed a rubber plug on the drivers side bottom of the back wall of the cab, thinking piece of cake getting the antenna cable into the cab. But I can't find the cable down there from the inside. Remove all the plastic on the wall behind the seat...can't find it.
Any recommend how I get the cable into the cab without drilling holes?
Steve
07 Limited
If you used the plug I'm thinking of it is down very low behind the rear seat about where the rear door trim ends. That's how I have the cable from my cap routed.
Don't forget to run grounding straps all over the pickup, and lots of them. I found a stake pocket mounted antenna to offer a very poor grounding plane, and be very disappointing in general.
This is a good write up on some of the challenges with grounding planes and vehicles in general:
Grounds, RF & DC
Grounds, RF & DC
Ok I'm massively confused now. What if I mount an antenna on a fiberglass cab?
I just yesterday installed a fire dept radio and antenna UHF/VHF. I mounted the an antenna on to roof rack rails on my cap. I have not call dispatch yet for radio check but I am receiving good.
Will this install work or am I going to have to ground the antenna base?
1 - 6 of 6 Posts
