I recently bought and built the rough country diy tundra bumper kit. $450 from NTW. It says its for 2014 but it fit my 2012 almost perfect. If you know how to lay a good bead this kit should be no problem for you. The directions are straightforward and clear(except the provided instructions are black and white, use your phone for color, trust me!) and easy to follow.I took me 8 hours to remove original bumper, tack weld the kit together per instructions, install and verify fit, remove it, lay it on the bench and weld it all up. 2 more hours to grind and clean, then primed it with a rattle can and sprayed it factory body color from oriellys in a rattle can.
