Rifle storage under back seat
23693 Views 32 Replies 12 Participants Last post by  clarktm1275_7459
Just figured out that the storage under my back seat perfectly stores a long gun.
Butt stock clearance is too perfect to be coincidental. Loving this truck more with every new Discovery.
1 - 20 of 33 Posts
G
Get one of these and you will REALLY love your truck. It is on my list....
https://www.esptruck.com/product-page/2014-2018-toyota-tundra-crewmax-long-box-under-seat-storage
Reactions: 5
Do you have a Double Cab or a CrewMax?
Would absolutely love an ESP long box! Did you end up pulling the trigger?
Sent from my SM-G975U using Tapatalk
Do you ever do group buys?
We just had one for the Dirty Deeds exhaust systems and we wound up with 50+ people.
Is that something ESP would be interested in?
I'd be in on that too.
RIGHT!?
I bet dozens of crewmaxers would get in on THAT.
Sorry just saw this thread. Not getting notifications from the forum anymore unless its a PM. So to answer your question, we would be interested in this. Lets see what kind of interest we have and I will look into it. The more we get the better the discount. Let me know.
Earl
ESP, I'm looking for a solution like the picture posted above (metal, long compartment for a rifle), but for a CrewMax. My understanding is that the CM solution only has the 3 compartments that can't fit a long gun. Is this correct? Additionally, the 3-compartment storage has the hinges on the outside, is there an option to have them on the inside? I know it's not a safe, but just trying to make it as burglar-proof as possible.
Here's mine…
This works
https://www.esptruck.com/produ...ax-long-box-under-seat-storage
Count me in!
A little pricey...
Yes, it does work... and probably the result i'm heading towards; however I feel it's not the ideal solution because:
- Hinges are on the outside
- combo/better lock options aren't available
- It would be great if offered in steel instead of aluminum.
The option presented by Fireman1291 is awesome; BUT requires you lose a 3 inches headroom. I have a CM and my entire family is over 6 foot. :(
I guess i'm looking for less of a storage solution and more of a safe solution. Something where I can leave a firearm in the vehicle for extended periods of time without constantly worrying about it.
It would be awesome if anyone offered a "safe" like Locker'down but in the form factor like ESP has.
Let me address your concerns.
Hinges on the outside: These hinges are more secure than a piano hinge that even law enforcement uses. I did a repair on a box for LA County Sheriff and that box had a piano hinge. I was able to take a small punch and push the hinge pin right out. Our hinges are steel with a stainless steel pin that is pressed in at 2 tons of pressure. The only way that anyone will get through the hinge is with a cutoff wheel. At that point it doesn't matter what kind of hinge you have.
Lock Options: We looked at several types of locks. We looked at the Combi-Cam Combo lock, we looked at BOLT, and we looked at some barrell locks. The Combi-Cam combo lock is very weak. The cam that actually comes with it is probably a little less than 1/8". Plus the top of the lock has a high profile and would cause clearance issues. BOLT was out of the question due to the body length of the lock. Would have lost a lot of room inside the box. We just could not find a decent barrel lock that would work. The lock we use has a heavy duty cam that has two bends in it for strength, and the cam itself is 1/4" thick, so it is pretty stout. Can you defeat it? Yeah, probably, but that is going to be true for any lock.
We could definately make it out of steel, but it already weighs 50lbs lol. I did one with steel lids for mine with the box still aluminum and it was 70lbs. Imagine if the whole thing was steel. it would weigh a ton. I almost took a finger off when I dropped one of the lids and didn't get my finger out of the way, haha:eek:
Feel free to get with me if anyone has questions.
1 - 20 of 33 Posts
