1 - 6 of 6 Posts
I am doing my first retrofit and I am facing an issue. Sorry for being noob but
1. I cut the housing with dremel and can't seem to fit the projector properly, should JB weld just do it or should I use 4 nuts and bolt to hold them in place
2. Should I be fitting the shroud (panamera) and then do the fitting or the shroud goes last ?
3. Will keep updated with pics and hopefully fellow members will help me go thru this
Cant seem to fit the projector and shroud together.
I Kick Hippies
1. Nuts bolts required for solid install.
2. Shroud is a trim piece, ideally should "complete" the installation, not "hide" the installation.
3. Pics of where you're at now would help us help you!
Wow that was quick.
Right now I will be heading to lowes to grab the nuts and bolt. And the second pic is where I am right now, trying to figure out how to fit it. Thanks for keeping up with me guys Dont mind if I come back for more help for wiring too.
P.S : I messed up the turning indicator bulb and melted it since I forgot to remove it while putting it in oven. lol
1 - 6 of 6 Posts
