1 - 8 of 8 Posts
You did mini h1's right? Did you just use a cone bit to widen the opening enough to get the projector base to fit through, then just screw them down?
No sir - did FX-R's, morimoto ballast's, and Phillips DS2's. I cut and JB welded. Works great. Don't have a photo on my phone. Sorry. .
Ok. I have a stupid question lol! I assumed the auto leveler just moved the bulb up and down. So the leveler moves the entire reflector housing? I guess it would have to. That puts me 2 steps closer to doing the retrofit.
Yup, moves the whole reflector housing. My first time doing it. The most difficult part was aiming them - and in my case while welding with the JB.
Ok guys, I have an unusual issue here. I retrofitted my housings on my 2013 Double Cab. Has anyone experienced a situation where the auto level feature is no longer functioning properly? Now when I adjust the lights down from maximum height, they move down at uneven steps. With a razor sharp cutoff this is a real hassle. Thanks guys.
1 - 8 of 8 Posts
