Replacement atenna help
805 Views 8 Replies 5 Participants Last post by  Mikecol
I have a 2011 Crewmax with a larger aerial antenna. I would like to replace it with a more flushmount antenna you would see on a newer vehicle but I can't seem to find anyone who specifically makes something of that nature. Due to its location/orientation on the hood and fender, it seems like it would have to be something sold per vehicle/application. Does anyone know of anyone who makes something like this that might work for my application?
Thank you.
1 - 9 of 9 Posts
Check Amazon. Last time I looked they had a bunch.
I got this one off Amazon & love it. I also tried a 4' off ebay but this one here from amazon did the trick. Hope this helps. I have a 2014 trd crew max.
Light Product Rectangle Font Tints and shades
Thank you both for the reply. I don't think I described it well because you are correct, there are plenty of lower profile antennas on Amazon and other websites. What I am looking for is something more like the attached (I probably should have included photos the first time - apologies). A standard one from another car will not work as they are mainly for flat surfaces and this one would have to be a model a company would sell per vehicle make and model as it would have to be molded to the hood/fender. I am asuming since I cannot find one and no one seems to know about them, they probably don't exist. Thanks again for the responses
Cable Bicycle part Gadget Wire Auto part
Plastic Office supplies Kitchen utensil Composite material Leather
Oh more of them share fins them go on the roof so you have to run the wiring all the way down
Search YouTube for Tundra Hidden Antenna. There’s also a write up on one of the other forums.
After trying many other options I found this hands down was the best. Added bonus is it will cost you less than $3.
Basically you flip the antenna mount upside down and your OEM antenna will be inside your fender, running horizontally toward the headlight.
I barely noticed any loss of signal, but the main benefit is it looks better, near OEM reception , and no more broken antenna mounts at the car wash!
I’ll see if I can find the links and will follow up.
Freaking Genius! The only thing better than a shorty antenna is NO Antenna. This is my next mod.
1 - 9 of 9 Posts
