1 - 6 of 6 Posts
My factory rotors and brake pads lasted >80k miles and I am very happy with them. I think now is the time to change both the rotors and pads. Looking for recommendation on rotors and brake pads I should go for. Should I stick with OEM or go for some after market upgrade? What are the pros and cons of diff options? Flexible on budget. Thanks for your time and assistance on this.
I’ve been happy with the factory stuff. I had TRD pads on and they have great bite without being finicky and a semi aggressive braking behavior beyond regular factory stuff, at the expense of brake dust and some pad life. To me, factory pads have a great balance of initial bite (though I do like the little bit more you get with the TRD pads), braking power, fade resistance, low noise, and low dust. My truck is never empty anymore, and I tow and haul often. The factory stuff has worked great for me.
Reactions: [email protected]
I don't think you can go wrong with the OEM stuff, but it is on the expensive side. I have used Wagner Thermoquiet pads several times and have been extremely happy with them. I can't tell any difference between the Wagner and OEM. I have used them on Fords, Honda's, and my Tundra's for years and they are great.
My last brake job (second brake job on this truck), I put O-Reilly Brake Best brand pads and rotors on and they also have worked great. The nice part is the Brake Best pads and rotors have a very good warranty (2 years I believe on the rotors) and they were much less expensive. If I remember right, it was like $400 a rotor from Yota and about $100 a piece from O-Reilly.
If your rotors are still smooth, I just put pads on mine the first time and did not turn them. Those rotors went to 140+k before I had to replace them. And at 140+K, they were just below minimum and could not be turned. For the price of rotors at O-Reilly's, it really makes it hard to justify OEM rotors or even spending the money to turn them.
At 75k i used Centric premium coated rotors , Bosch semi ceramic Quiet Cast pads on the front , and the Wagner ThermoQuiet pads on the rear .
5-8K later , very happy . Quiet and stops quite darn well . Low dust . However some of the Centric E coating has burnt and lil rust forming . Which has been my general exp with any aftermarket coated rotor , the coating only lasts a while ( in the rust belt ) . PS. I am not hard at all on the brakes , but we do have hills and such in my area .
good luck.
1 - 6 of 6 Posts
