Warhammer05, I just replaced my front bearings on my 14 tundra CM. From what I know from experience and still dealing with a couple issues, If I were you, I would by the whole bearing hub assembly. I choose to buy just the bearing and do the pressing myself. Well, 4 bolts, a tug and you put the new bearing hub assembly on and 30 mins later your good to go. If you choose the other route, you will need a press, a arsenal of plates, numerous size round bar, a couple hours to spare, special tool, new seals, grinder to cut off bottom bearing race, and list goes on. By spending about a $100-$200 more, you will just have 4 bolts to deal with. 3 weeks later Im in contact with a toyota master mechanic trying to figure out why I have ABS & slip indicator lights on.
Buy the whole bearing hub assembly, do it yourself and save money and the headache!!!
Hopes this helps you buddy!!
