After putting Sumo's and extended shackles on to get 1" of rear lift, it is more apparent that my driver side rear is about 3/4-1" lower (closer to frame) then the passenger. This is with just a few gallons of fuel so it's fairly consistent. I added the sumos for towing and they work well, I added the shackles to get off of them a little for better empty ride, which works most of the time, but the one side is noticeably lower. I have adjustable shackles. Should I consider moving the driver side only up a 1/2" hole to level it side to side? The problem is that side is just barely touching the sumo so it gets some bump from time to time. I know you wouldn't do that on the front, but what about the back?
