What do you guys suggest I do to get rid of this squatting when my boat is hooked up?
a bigger motor for the boat.What do you guys suggest I do to get rid of this squatting when my boat is hooked up?
It's not the boat, it's the weight of all the dead bodies in the bed that's causing it to squat.I have a 21' Triton...my truck barely squats. What's up with all your squat with the boat? Boats aren't that heavy.
woops just saw this. Sounds like you just have it loaded. (not a boat issue). But the point still stands, move weight from the bed to over the trailer axles would be a simple thing. Else increase loading capacity of the truck (already pretty highly rated load capacity, so if you up the suspension you want to be sure it still stops in time, etc, with that much weight).It's not the boat, it's the weight of all the dead bodies in the bed that's causing it to squat.
How do the OME ride? Did you get the 2.25 lift and did you use poly bushings?
Sorry for hijack, OP
