Tried a search didn't find anything with what I asked. Is it possible to make the manual rear slide to a motorized one? Or is it a splicing and complete wiring job??
What year Tundra are you referring to? Give me the year and I can check if there's even a power slider available for it. I don't think there is but can look into it for you. Even then if your going from manual to power you'll have to wire a switch to the power slider to operate it. Power sliders come with motor and all already attatched as a single unit.
EDIT: Sorry just reread your question - there is no way to "convert" a manual to power. Two different animals.
It's a 2011, thanks, I guess I was kinda vague. Figured may have to wire from front to back, but maybe like the info buttons I just installed maybe there was a wiring plug located behind a panel to do so.
I really wanted the roll down rear window but this truck had everything but that. Maybe the next one
I researched it when I got my 2014 SR5.
It would cost over $1K for parts and labor, since you'd have to replace the rear window....
https://parts.toyotaofcoolsprings.com/auto-parts/2015/toyota/tundra/platinum-trim/5-7l-v8-gas-engine/body-cat/glass-and-hardware-back-scat
That rear window 64810-0C080 is getting hard to find and most dealerships won't ship it..
But there is one left on Amazon...
https://www.amazon.com/Genuine-Toyota-64810-0C080-Window-Assembly/dp/B00G0M9W3S
https://www.parts.com/index.cfm?fuseaction=store.PartInfo&PartNumber=648100C080&VehicleID=410243&diagram=8193853&Title=-HORIZONTAL-SLIDING-WINDOW-W/POWER-Toyota-BACK-GLASS
2011 parts..
https://parts.toyotaofcoolsprings.com/auto-parts/2011/toyota/tundra/limited-trim/5-7l-v8-gas-engine/body-cat/glass-and-hardware-back-scat
I'm pretty sure my 2014 is already wired for the sliding rear window.
I know there is a wired plug for it behind the dash.
I do miss the rear window going down in my 2005 DC.
I guess my next Tundra will be a crewmax, just to have the rear window that goes down...
I remember having to convince my salesrep to double check his facts after he told me "no power rear glass in DC".This was in 2010.I seldom use it,but it wasn't much $ to add to the option list.
Discussion Starter #7
Thanks for the replies, I just thought it was silly to have a manual sliding window way back there. I doubt I'll ever use mine unless I have a passenger back there that wants it open
Lowlife, the full roll down is only avalible in the crewmax? I guess I didn't realise that, I'm new to these trucks, wanted one for a long time and jumped in feet first lol
