When you measure from the lowest part of the fender opening on the front of the rear tire to the tire, is the measurement the same on both sides? And then the same measurement from the back of the tire to the fender well. The front measurements should be close to the same and the same for the rears. However, not the same for the front of the tire measurement and the behind the tire measurement the tire is not centered in the wheel well.
If these measurements are not consistent you may have a centering pin on your leaf springs that is broken and has allowed the leaf springs to slip forward and or backward. I found and repaired this issue on a friends truck after it had been to an alignment shop. The truck was scrubbing the front outer left tire badly. The alignment shop told us the thrust alignment was out but that the shop aligned the front axle the the rear. I did not like that answer so I started looking for the cause. I found the right rear tire had moved to the rear about 1 3/4 inch. This caused the truck to crab walk when driving straight all while grinding off the left outer front tire.
I jacked up the truck, placed the hackstands on the frame so the tire was only about 1-2 inches off the ground. Then placed the jack under the axel. Removed the nuts on the U-bolts and lowered the affected side to the ground. Placed all of the leaf springs togather properly with a new center pin and reinstalled everything. Then we took the truck back to the alignment shop and had the alignment done again.
