Has anyone that installed the Rigid fog light kit used rigid covers? Curious if they will fit between the bracket and light.
Wanting to put in some SAE lights but also want to be able to use the amber covers
Thanks.
I don't think so. The bracket uses the middle screw on each side from the light to mount to. The cover goes over the screws. Unless you drilled a hole in the cover and got some longer screws I don't think it'll work.
They will not fit with the brackets
