Ok so I have a 2011 Double Cab with 3 power plugs in the cab. They only work while the key is on. As soon as I shut the truck off the plugs go dead. Is there a way to change that?I need to run a phone charger off one of them while I'm camping.
You'll need to wire one straight to the battery, or find a constant power source inside the vehicle you can tap into. Maybe a light circuit.
Do yourself a favor and run a separate circuit, separately fused at the battery. Use properly rated 20 amp-rated wire gauge for the wire run distance and a 20 amp fuse at the battery. This will allow this to be your "super outlet", considering the the stock outlet is only 15 amps.
