1 - 10 of 10 Posts
Good morning gents,
I am going to PD my TRD rear sway bar this weekend to black so it will go with the rest :D. But i have a few questions:
1. What kind of prepping require?
2. Do i need to use primer?
3. How many coats do i need?
4. How long does it takes to cure?
Thank you so much for your time.
Steve
"A Man Needs A Maid"
1. Clean it good.
2. No
3. 4 or 5, the thicker the better for under the truck
4. 5 minutes between coats, will be dry in a few hours.
Reactions: danoh
1. Clean it good.
2. No
Thank you brother. Will give it a shot this weekend.
I also painted mine black but I used PPG Trim Black Paint, skuff surface with 200 wet/dry sandpaper, wash, dry, paint. Let sit for a good couple of hrs before re-installing.
Thank you. But i want to retain the original color just in case i change the color of my truck some day to red :D
Personally I like the color of TRD rear sway bar.
Banned
1 - 10 of 10 Posts
