So unfortunately EPS doesn't make a P3 Brake controller mounting kit for 2007-2013 Tundras :(
I would prefer not to use the small cubby in front of the center gear shift as I like that spot for storage.
Has anyone carved out a hole or modified the area below the traction control button (near the ignition)?
My truck is a 2013 Double Cab Limited if that helps.
I've had the P3 controller for a while now and delaying installing until I'm happy with its final location and how I am going to make it look good and mounted in a functional location.
I guess below the tow/haul button might be my other option. Looking for advice from fellow 2nd gens.
I think you would have to cut up that cubby pretty good to make the P3 fit.
The Primus IQ does fit nicely though...
