Did they check the fan clutch? It is one of the most over looked items
Was going to say if you can find another trailer to test out but you beat me to it.Opened a case with Toyota, but it’s pretty much been a dead end of no call backs. Took matters into my own hands this morning and replaced the fan clutch as well as the temp sensor. Same as before, no leaks or overheating at all without the trailer. I’ll test it with the big trailer tomorrow. Going to replace my trailer bearings and brakes in the morning in case the brakes are worn and causing slight drag causing the truck to run warm. Trying to eliminate all potential problems.
Yeah, I keep kinda going back to that too. I saw those threads as well with the broken pieces in the crossover tube. That broken cap was the start of all my issues. I worked on the trailer all day today, I put all new bearings, new brakes and drums. Damn truck is still running warm after the test run. What’s strange is, it’s only getting warm with the trailer on, and around the 1200rpm range. At higher rpm’s or at idle/stop lights…. it comes right back down. I took my boat fishing yesterday, boat weighs less than 1000 lbs, and drove 45 min each way and zero issues. But as soon as I hook the big trailer up, the temp starts to climb.Jumbo, I would wonder if when the cap failed some of the seal is clogging a water passage. Seen it before on here.
And I would have said to look at the fan clutch, which you replaced. Just realized I haven't been around to browse, late to the game.
I have, same results. After completely ruling out the trailer, and replacing every component in the cooling system, we are 100% convinced we have a small flow blockage. It really can’t be anything else at this point. My buddy is going to take it home this week and tear apart the coolant jacket and find the blockage. He’s convinced theres a piece of that broken cap blocking the flow. He’s a very good mechanic, I’m sure he’ll come up with something. Got to Tier 2 complaint department with Toyota, but big surprise…no response in two days after many calls.Have you tried turning your heater and fan on full blast to see if that drops the temperature?
Keep us posted with your results. We can all learn something here . . .I have, same results. After completely ruling out the trailer, and replacing every component in the cooling system, we are 100% convinced we have a small flow blockage. It really can’t be anything else at this point. My buddy is going to take it home this week and tear apart the coolant jacket and find the blockage. He’s convinced theres a piece of that broken cap blocking the flow. He’s a very good mechanic, I’m sure he’ll come up with something. Got to Tier 2 complaint department with Toyota, but big surprise…no response in two days after many calls.
I’ll be placing a special order on a new F-350 in a few months. If I can make it last until the end of the year I’ll be in good shape. This whole ordeal has been driving me nuts, trying to run a small business with an overheating truck is not fun.
Dont know about the construction, but TRD is rated 18.5 psi compared to a typical 15-16 psi cap. TRD raises the coolant boiling point about 10 ºF.Radiator cap:
Toyota OEM 16401-36020 retail about $21
TRD PTR040000003 retail about $38
I wonder if upgrading to the TRD cap would avoid the plastic failure problem of the OEM?
