Offical TechStream software thread( settings and such)
903206 Views 2669 Replies 468 Participants Last post by  Dusja
Offical TechStream software thread( settings and such)UPDATED 1-31-2015
I updated my OP today 1/31/15
I have TechStream installed on 2 Pc's windows 8 or 7 non pro 64 bit. Im using cable MINI-VCI J2534 (Bought this when I originally posted this thread/Post in 06-26-2012
here is the work around link for windows 7/8 64 bit I did not update the firmware on the cable. I would leave yours alone.
http://www.ft86club.com/forums/showthread.php?p=1920724
Follow the Directions to a T and it works! big thanks to mendonsy and Robert_W and others.
Software Download link for TechStream version toyota-techstream-v9.30.002
https://www.dropbox.com/s/gl6r90tvw8uuee7/toyota-techstream-v9.30.002.zip?dl=0
Here are the 64 Bit drivers
https://www.dropbox.com/s/029qetxp67kg70z/Toyota Techstream V9.30.002.exe?dl=0
I did not intall or click on the Video guide(for 64bit)
Your antivirus software might come on and detect a trugan horse. I disabled it before I began. No problems that I can see by doing this. Do so at your own risk. :nerd:
this seller has the cable and software
http://www.chinaobd2.com/
thanks
SP :D
edited: I have not tested these driver and "current" drivers and software but here they are as of 6-24-2017
tdi200 said:
Hello i bought techstream software and seller from ebay sent me a link to download the latest software and i wish to share it V12.00.125
https://mega.nz/#!twRCVRaK!BqNvjIf2QCUygoAgxI1t2xNyhhlCqlc9YHUYW03qzOU
32bit
https://mega.nz/#!9hgSkITS!be1K9yKCHZEAaFajishFYa5oLQUmWvgsbJSA8MVMFfA
winRAR32bit https://mega.nz/#!Vs4A3ZDQ!0UGD2ez8dTQIBxpNKIEB4r7SPkZBYNToexvT4kEcmkc
winRAR64bit https://mega.nz/#!0tJgxDxK!2cosP4qSv9ShHkIBWWDhFiIl8jU2Wv8ltZIG2ZuKh8c
unzip it by winrar or other program , you will get a floder with all files , Just follow the instruction step by step .
Reactions: 5
2621 - 2640 of 2670 Posts
You're familiar with the definition of insanity? :p
I've tried numerous times, and it's not connecting.
As far as I know, there's three possible issues... (1) the cable is bad (2) there's a problem with my truck (3) there are driver related issues. After having installed the software and drivers numerous times, including after a Windows recovery (fresh-reinstall), I'm fairly convinced the drivers are not to blame. However, I'm not ruling it out completely.
Hence my question, is there any trouble-shooting one can do to determine if the cable is at fault?... Or is there some way to determine the drivers are not installed correctly? And short of finding a new truck, is there any way to know if your truck is the problem?
i suggest you to please check post #2,080 it explains about the drivers and how to confirms if the cable is detected
what year is truck?
also if everything is failing for u, u can always always install vmware that i have included on the post #2,084
you can use this v14.30.023 techstream setup file comes with keygen: (good for vehicles upto 2019) Techstream v14.30.023 WITH KEYGEN.zip
In a demonstration of my insanity, I reinstalled everything on a fresh install of Windows 10 and I'm having the same issue... any idea what's wrong?
area of confusion, based off screenshot u had uploaded on here shows that techstream was up? ruggb said he could not run the program can you suggest ruggb what to do so that he can run the program? or both of u guys got the same problem?
what year is truck?
Thanks... I did that this afternoon... installed the VMware image with the v12 Techstream that was posted above and again, I got nothing when I connected the cable. I think my cable is dead. Nothing is detected when the cable is connected... no drivers install. I installed the drivers using the setup utility and ran FrimwareUpdateTool in Win XP and it could not find the cable either.
Unfortunately, as you can imagine, support for these things is horrible. I will probably have to buy another one.
It would be ideal if there was a way in Win 10 to determine if the cable and drivers are installed and communication with it is working. It seems to be an all-or-nothing affair with no one really understanding what's going on, so if it doesn't work, it's just start over... hence the insanity. :) I was hoping someone here actually had a deeper understanding of what's going on but alas, it remains a black box.
whenever u get chance check #2,080 it explains what happens when u unplug the cable from the computer at device manager. that confirms if ur cable is up and running or its not
for windows 8 users and above can go to device manager and under "universal serial bus connector" open the drop down menu and have the cable connected to your pc and you should see "USB SERIAL CONVERTER" that confirms that your cable drivers were configured correctly. and when you unplug the cable the usb serial converter will disappear
Ok.. In Windows 10, I get nothing showing up in Device Manager. Definitely buying another cable! Thanks!
Hey guys, I recently installed TS v16.00.017?
everyhing works fine EXCEPT I only have the option to turn the passenger side seat belt warning off, I’d like to turn the driver side chime off … also I have no options to adjust the turn signals ..
I’m running in offline mode with a tactrix interface
Thanks for any help
Thanks for any help
Cant predict much but did you do the basics? Did u try to install v16.00.020 before reporting the issue? as you got the older version than what we have provided here on post #2,604 try installing that instead. Also first uninstall you 0.17 using revo installer clean everything. Revo uninstaller pro is also provided on post #2604
Sent from my LM-V600 using Tapatalk
Yeah, all the basics, instead of doing a clean uninstall I ran the newer file and it asked if I wanted to upgrade my current version, which I did , everything works fine except I have no option for driver side seat belt chime or the tap to turn signal options 🤷🏻‍♀️
07 DC 4.7
07 DC 4.7
Weird that when you uninstall and install new setup file it asking you to upgrade? You sure you uninstalled the old version using revo as i had suggested to do?
Since you got 07 year vehicle can you try to run older version techstream (version 11) that is provided it includes keygen'too. (Of course uninstall the current version) NEVER UPGRADE its like you just carrying over'setup file thus explains why you havin same problem because you did not uninstall instead you just ran the new version setup file
Of course use revo uninstaller and make sure that indeed software is uninstalled before installing new version.
As undeR any install you should never get a prompt for upgrade unless you never uninstall the software first.
With techstream you should always use revo uninstaller to totally remove the software than restart pc and than install the other setup file
I’ve tried both versions, both have the same options but maybe my year 07 doesn’t support the driver side seat belt home removal
PLEASE DO NOT ASK FOR KEYS AS TECHSTREAM V14 COVERS CARS UPTO 2019 AND MOST OF US GOT CARS OLDER THAN THAT!
(LETS BE HONEST MOST OF US GOT CARS OLDERS THAN YEAR 2016 AND V11 AND ITS KEYGEN IS INCLUDED TOO THERE IS NO POINT OF HAVING NEWER VERSIONS IF YOU HAVE OLDERS CARS)
i suggest using revo uninstaller to remove your previous installation as the program will help u to remove everything related to the program you are uninstalling here is the portable versison click>>>>>> Revo Uninstaller Pro.zip file also uploaded on MEGA: 24.31 MB file on MEGA
THIS INFO BELLOW IS ALL YOU NEED TO RUN YOUR TECHSTREAM FOR FREE!
There is V16.00.020 no keys needs all you need is install the exe file and than paste the loader (patch) to the installed directory and than run the pasted loader or you can right click and send it to your desktop as shortcut and run it. here is the MEGA link CLICK>>>>231.87 MB file on MEGA
: (good for vehicles upto 2019): CLICK>>>> Techstream v14.30.023 WITH KEYGEN.zip
KEYGENS!
TUNDRA TALK DEDICATED KEYGEN IS ONLY DESIGNED FOR V14.30 that was created by our member @captaintofuburger
Keygen for v14.30.023 = CLICK>>>> TechStreamHelper-Binary.zip
v14.30.023 Browser based keygen = CLICK>>>> version 14.30.xx keygen.zip & HTML, CSS and JavaScript demo - Liveweave
our other member @oleg64 provided keygen that works for v14.10.028 & v14.20.019 but not sure how safe this script is unless oleg64 can give us more info on that here is the keygen mega file: CLICK>>>> 161.2 KB file on MEGA
64BIT MVCI CABLE DRIVERS with Free software (7Zip) to run RAR file: CLICK>>>> 7zip&drivers.zip if link gets take down use this: CLICK>>>> 8.02 MB file on MEGA
and for those getting java run time error message when opening the program here is the file you need to install for the error to go away: CLICK>>>> Java_v7.0.5.exe
techstream v11 with keygen that can generate keys upto v12.00.125 and all the drivers need to run the program; link consists of EVERYTHING you will need to run the Software (64 and 32 bit drivers for the cable will work on any version of techstream): CLICK>>>> Techstream+vmware+winxp.zip
and also for blocking techstream program so it DOES not connect to internet for auto update and mess things up
go to start-controlpanel-windows firewall-advance settings-click on new inbound rule locate file C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin and look for the file "MainMenu.exe" and follow instruction and make sure to click BLOCK connection and repeat the same for outbound rule
Cable that i bought: mini vci V2.0.4
can be found in usa but out of stock: MINI-VCI J2534 OBD2 USB Communication Interface for Toyota Firmware V2.0.4 (Cable Only)
thanks tdi for all this information. i'm new to toyota's and techstream. i have version 11 installed and i believe my cable is working connecting.
my problem is that techstream prompts to update and it won't let me past. is there a work around for this?
i see the "auto update" solution here,
Product Blue Font Screenshot Software
i have a connection error. can anybody help with this. i believe i have the cable drive installed correctly.
i got it figured you need to select xhorse in the setup menu.
Hola;
Tengo Techstream 14.20.019 instalado en Windows 7 funcionando correctamente.
Entro en un toyota rav 4 de 2008 para codificar una nueva llave y meda este error:
Computer Personal computer Font Operating system Display device
Hace varios meses grabe una llave sin problemas en un toyota auris de 2009.
Alguien sabe porque me sale este error?
Gracias!!
Im getting the same thing and don’t have a clue on what to do. Im freakin dumb about it….
Sent from my iPhone using Tapatalk Pro
Hi, if u in usa i can try to help you out around 8pm EST today and see if we can have you up and running. Just install team viewer and private message me
Also Check post number #2572 shows solution to your issue
