2281 - 2300 of 2309 Posts
Out of curiosity what year is your camry? Manually entering probably means that year of camry is not in database? I have the version 15 mega its 2020 February version if u wanna give it a try?
Sent from my LG-H811 using Tapatalk
tdi200, could you please provide the keys for:
v 15.00.026
S/W ID: 8BE7AC1D8ACECAC65B6AF645D27B1F05
Thanks
NA: E1A31ABA6A3ACAF9B0D9D8B22512376650292002150603
ЕС: 280e4cd2f4a4fe57434311f02999b48b50292002150603
JP: 6e47efc6b228060020201529c47caf35b7745c79f9d1a5
OT: 998454666d94e124f75e321b6908ef9850292002150603
США: E1A31ABA6A3ACAF9B0D9D8B22512376650292002150603
Thx. But the North America key did not work.
Ver: 15.00.XXX
NA: 6c9fc1e9e3003b18856f99efc141ef9350112002140659
EU: 966fa656e013900b195b7854da44747d50112002140659
JP: d64b92081434060025201411f9d14b9553119d0e124813
OT: 19dfe5744469f95869e400c11274d7e650112002140659
@tdi200 can I get reg codes for 15.00.026
ID = C6E493DD0DEE66043BBE6332C08EA204
thanks
v 15.00.026
Thanks
Ver: 15.00.XXX
NA: 7b4b92f2d99bf34195c2775cdb76d94e50112002151819
EU: 5d4ad9cb32225b8936e1c0f9d5060b2450112002151819
JP: 8408719a23e5180021201511133c1b957e26b412ff56ce
OT: 1a134b21e91fc9e3e49f81e4322d1d0d50112002151819
Ver: 15.00.XXX
Thx. S/W accepted the NA key.
SW ID: 84193D3A357805F1AF82FCE95CA0C301
SW VER: 15.00.026
Thanks.
15.00.XXX
US: 20c942e3b8480af3c511db9c4fae00ca50292002160458
EU: 4efdcf8b99243dde69b21c9397cccbf950292002160458
JP: 568522f0b26a0400252016294b32c385f2864d1fcc313d
OT: 5d3dad8c4c2b0a456d2fbbc34c3bf74a50292002160458
15.00.xxx
Ver: 15.00.XXX
NA: cd0e78738c473dc9436363939cc3722150002002161545
EU: f05bd5eae2e9658100b1179ed9c793f050002002161545
JP: d9384ca6845415002420160042f25e55dc547a8e4d74f7
OT: 6a0e250f126f11dc9659eee73b35822650002002161545
Confirming that for v15.00.026, with 2019 Camry, the car was not automatically recognized, but once I entered the info manually in TS, the car connected showing the correct odometer (no VIN) and all functions appeared to be there including Health Check and Customize.
its strange why it does not auto recognize but quick question, when you connect the cable to the car, whats the status of the car is the car completely off or you turn to key to ON position? i always keep the car to ON position (final position before the cranking position)
Where do I get the software?
With the car off, laptop on and running TS, I connect the cable to the car, then put the car in the ON mode (It's a smart key/push button, so foot off the brake, press once to ACC, 2nd time to ON, engine not running), select Connect to Vehicle in TS. I was led to believe that connecting the cable to the car should be done with the car off to avoid possible ECU issues. Others have reported their car not being auto recognized including at least 1 other Camry, I wonder if it's a 2019+ thing as I believe I read the Lexus 2020 behaved the same with v15.00. Thanks for your interest.
