2141 - 2160 of 2191 Posts
Ver: 14.20.019
NA: c1105e00fc53791e416516bdb02d0d5250172001111906
EU: dd39bb1e37be91438a319c7ac6a27e1950172001111906
JP: 236fc13b04fe1900102011176c4fd76519b3bd4f068bc6
OT: ffea3f1fe3bff6e7d630e42e6b86017e50172001111906
Thank you @tdi200 tried the v2 cable and still same result.
Also still having the same result with v1 cable. Must go to body ECU first and enter Active Test before I can go do Active Test on Multimeter.
I will test v2 cable on different laptop to verify whether it's bad cable.
Are there any difference in driver for v1 and v2 cables?
Thanks again for your help.!!!
as far as i know the drivers are no different for 64 bit that i have it on mega, but before you try another laptop why dont you install the VMware on your current laptop like u claim u downloaded the mega file i uploaded it has everything and than install winxp on it install all drivers of the cable and run the firmware update tool to see if the cable is even detecting? u just hit connect on the firmware update tool program do not update the firmware
May I please have a key?
man in the mega file there is a keygen that u could have generate it yourself and second problem is you did not type in the software id (by coping and paste it here) instead u took screenshot and i had to manually type the numbers and it was a huge hassle here are the keys (yes i had same issue typing all those numbers to request the keys for u now its your turn to face the pain i went through inputting those numbers and hopefully i didnt miss the numbers from the software id u had given me
I copied & pasted it. Thank you.
Ver: 11.20.XXX
NA: c62d699621c44ac48211500bf1fa443750302001160132
EU: 033921314abfc6384bc64092fed3e84050302001160132
JP: 46b75e3aef17f2713aa2c2f4131afffd50302001160132
OT: ccccc2dcf89c77061419786d108f420950302001160132
Ver: 11.20.XXX
Thank you. It worked but says it's obsolete and has to be updated.
I'll look for the newer version.
Toyota Sienta 2006
Toyota Camry 2013
Toyota Prius Plug-In 2014
you do not need v14 the version i have included at post #2,084 there is a mega link there that includes techstream and its keygen which is perfect for your cars so u can install the software and run the keygen yourself but this time i have i have given u the keys i usually dont if your car is older than 2017 v11 is best fit for u which can be found at the post #2,084
Ver: 14.30.XXX
NA: 49e6c4f5c5127a8122c44d49a4304d5850172001181811
EU: f130bc0f20cf28c6142838d6b93ace4a50172001181811
JP: be43cec2bb3518001120181707cf211533a397ab1ab9cd
OT: 0ef1fed6cc9c926a0566a00725fa8a3c50172001181811
Ver: 14.30.XXX
Thank you
I have a 2010 5.7 CrewMax Tundra.
I installed 14 the info is:
80D3A2F88BFDA85BC85B7B9DBDD23206
Version 14.00,018
Thanks in advance for the key.
you do not need v14!!! the version i have included at post #2,084 there is a mega link there that includes techstream and its keygen which is perfect for your 2010 just follow instructions on that megafile
