2121 - 2140 of 2191 Posts
Version:14.20
Thank you very much!
next time please include the year of the car this is the last time i am doing this, from now on if i dont see the year of the car i will not respond
Ver: 14.20.XXX
NA: 94eb40ace3ffe1cb118d6084ba50015850252001021304
EU: db022c70c42b5c90bcafb81779340b2950252001021304
JP: 5c9f91f3da51130010200225d8b1da453c34dd2e207a93
OT: 206dde2df7e3091640d0ec7c5e8d9fdc50252001021304
Ver: 14.20.XXX
NA: c04f965666d05139fbee00b462c7ec2350112001021304
EU: 4286f20729808df6ce6f70171242f1a150112001021304
JP: a11af498b613130010200211cf109145cde77dc78a261e
OT: 523a7c5172ea58dac8e6ea4a27e7f35c50112001021304
Ver: 14.30.023
I asked other forums if they could help me out with the registration key and I got no reply
Could you help a brother out in this car community?
car is a 2008 Toyota Crown GRS204
Ver: 14.30.023
you dont need v14 for your 2008 crown instead please check post #2,084 there is a mega link there that includes techstream and its keygen which is perfect for your 2008 toyota crown that link has Techstream v11 and a software to generate key so please use that link under post #2,084 and also here is the megalink to make it easier for u the link includes everything you will ever need
Ver: 14.30.XXX
NA: 17250d1af76ff82008ef29f2c605b8fa50252001041713
EU: 139d6c6c6dbd657aa0757dd2fdabdc4b50252001041713
JP: 89a47dfb08691700112004255c9b2d3592499e43712274
OT: 42f227d359be2f208aaf225660a2a8a050252001041713
thanks tdi200
but will it work on windows 10 64bit? that's the reason I wanted to try the v14
thanks tdi200
yes works great on windows 10 remember techstream is never issue the issue is the drivers of the cable!! if you are familiar with windows, try to see the folder techstream gets installed to on a 64 bit computer, u will see its under x86 program files, that shows that techstream always runs on 32bit
thank you! will download the file asap
and if its too much for u here is the keys for ur v14
Ver: 14.30.XXX
tdi200,
Thank you for offering to provide the keys!!
Could I please get the keys for:
Vehicle: 2019 Camry
Software ID: 462ECDD261530479EDF6126CD82CF703
Software Version: 14.30.023
Thanks!
Ver: 14.30.023
NA: 11756ac9977fc9006ce37707270f481e50002001061249
EU: 1d053d8ad67b5b492c15b6589a68721450002001061249
JP: 16cee279ebc51200142006005b274195425afcff9bda18
OT: 222e5530d59688f1e0c12ea40a09c36550002001061249
Ver: 14.30.023
Thank you! The software accepted the NA key, no issues.
Guys-
I stayed up all night thinking about how to make this easy on everyone so ended up coming with an idea of virtual machine.
What is a virtual machine?
A virtual machine is a computer file, typically called an image, that behaves like an actual computer. In other words, creating a computer within a computer. It runs in a window, much like any other program, giving the end user the same experience on a virtual machine as they would have on the host operating system itself.
So I found VMWARE as our software to create the virtual machine and later on that night I was able to find windows XP 32bit and tried installing xp in the vmware and turns out to work great, so with that being said I combined AGAIN all the files including vmware, winxp, techstream and its drivers as well
I installed winxp on vmware turned out very well to an extent that when I connected the mvci cable it auto installed the drivers I did not even have to manually install the drivers not sure how it happen it could have happened because at that time my winxp virtual machine had already access to the internet. And might have downloaded the drivers itself
Here is the video someone installing xp in vmware (
) video is old but almost same concept please do check the instruction txt I have included in the notes I have made this very easy for everyone
Below is the link of the file 1.24gb
as usual please dont forget to block vmware to access the internet using windows firewall block these two files both inbound and outbound rules
ProgramFiles(x86)\VMware\VMware Workstation\vmware.exe
ProgramFiles(x86)\VMware\VMware Workstation\vmUpdateLauncher.exe
also when winxp is installed on vmware, u can easily drag files from your host computer to winxp (all them techstream files)
file includes:
Techstream v11 (good for the cars/trucks manufactured upto 08/2016)
Techstream keygen
VMware
VMware keygen (I have extracted about 10 keys in notepad)
Windows xp sp3 iso
32bit and 64-bit drivers for MVCI cable
software for checking your cable version.
Please do check the instruction included in the download and installation will be a breeze I have also included screenshot of vmmachine to make it configured right so that usb devices are detected these pictures will make more sense of what I am trying to say
Hi tdi200,
I have both the older cable and the new 2.0 MiniVCI cable.
The seller from Taobao was not able to get the MiniVCI cable to work with my Lenovo laptops.
I do have an older Toshiba and a 1st Gen Surface Pro that I have successfully installed up to v12 with the old cable.
But the problem I am having is getting the Active test to work with old cable.
I have a USDM 1999 Lexus GS300.
Would this v11 allow for Active test to work with old cable and/or new 2.0 cable?
Is the driver included with the 1.2gb file for the new 2.0 cable?
Thanks
Hi tdi200,
Thanks
FIRST THING FIRST!! MAKE SURE YOUR ANTIVIRUS IS OFF or else it will trigger false positive
99.9% of the Reason why active test dont work is because the techstream version is patched, unlike the one in mega link provided its untouched version so install that one and use keygen (also provided in the mega link) for techstream to register the program
if you have v2,0 cable i suggest using version 2.0 first and see the outcome as the cable drivers provided in the link which says drivers for 64bit works perfectly in the 32bit as well so u can install that driver folder
and yes 1.2gb includes everything you will ever need to run techstream this a bullet proof version because i also included vmware and active test will work and after successfully installing the drivers and techstream v11 u will have freedom of trying different version of cables v1 vs v2 and see if you get the errors while doing active test
and also u dont need to install techstream on older computer i myself and other been using techstream on windows 10 so go ahead download that 1.2gb file and follow instruction and remember to use the 64 bit drivers and you should be fine.
p.s drivers of v1 and v2 of mini vci are the same but please focus on the "64bit drivers" folder in megalink to install the mini vci driver in your lenovo laptop!
report back and if you get issue along the way message me and i will help u out just install teamviewer so that i will be able to connect to your computer!
Ok so here's the result so far.
I installed on the Lenovo the v11 in the Mega link and the 64bit driver installer included.
1. I was able to get the old cable to be recognized and operating. But still unable to get Active Data. This applies to my Lenovo Laptop and my Surface pro.
2. I tried the newer cable but was not able to automatically recognize the vehicle. Once connect to the vehicle by manual selection I cannot access any of the ECU menus. This applies to my Lenovo and my surface pro.
I installed v12.20.024 on the lenovo.
a. I cannot get Active Test to work if I go directly to Multimeter. But! If I go to Body ECU first, go to Active Test, then I can go back to multimeter's Active Test to get functions.
b. I still cannot get newer cable to automatically recognize the vehicle or Connect to ECUs even with manual vehicle selection.
The newer cable is not showing any device driver not being installed.
The firmware update does not work at all on win10 64bit. even in forced compatibility mode.
Photo below are both cables. Left is old / right is new.
Would a different (newer/older) version of Techstream be worth a try?
Any other test to suggest?
Thanks
881028
881029
hello
99gs300tw,
sorry for late reply got really busy at work anyways the information you provided is insufficient for me to picture the problem you are going through
because:
1. you have not mentioned if you had previosuly installed any techstream on your Lenovo before the megalink? if you did, its a must to uninstall that version before installing the v11 from mega link,
p.s use revo uninstaller to uninstall techstream completely
2. you did not provide any info on v12 how u installed it? did u had to put the keys or you replace exe files?
3. you mentioned you installed techstream and 64 bit drivers but did not mentioned if you used the keygen to register the program ?
4. you mentioned v2 cable was not recognize but did u make sure to check VIM option on techstream to select the correct cable?
5. take sometime read previous posts on this forum it was confirmed v11 was able to do active with no issues at all if you still having issues please pm so we can setup a teamviewer and see if i can help u out
6. yes firmware update thing does not work on windows 10 it works great on windows 7 and xp that firmware update tool is just for making sure your cable is detected. also in the megalink vmware is included and windows xp u can install vmware and run xp on it and u will see firmware update tool will work just follow instruction on that mega link to install vmware
hello,
because:
V11 was loaded with the mega file version. Used the key gen to registered the program.
v12 was upgraded. Since the key gen did not work for v12.20.024 I used the mainmenu.exe replacement method. However, it did still ask for a registration code and the codes generated from v11 worked as the ID displayed the same.
There was previous attempt to install by the v2 cable supplier.
I did a standard uninstall of the v12.20.024 previous install using windows program manager,
Installed v11 from mega link.
V11 did did not work for Active test on both cables. V2 cable did not work. VIM option on techstream was verified for Mini Vci
Upgrade to v12.20.24, replaced mainmenu.exe in bin directory.
V12 can do active test with old cable if I use Body Ecu Active test first, then go to Mulimeter.
V2 cable still does not work. VIM option on techstream was verified for Mini Vci. User was set to corporate.
Will try Revo.
V11 doesn't seem to work for active test at all. I've tried every ECU in techstream and still displays error (some function unavailable?)
V12 works only if starting at a certain test.
Thanks
Will try Revo.
Thanks
never upgrade always use revo to uninstall the program, than restart the pc and install whatever version you got and try to avoiding patching mainmenu.exe specially if you see the keygen supports that particular version v2 version is not working i can guarantee you that its user error issue u might have to update the driver manually check post #2,080
Is there any Meag link of v12 that the key gen can support?
Just tried again after Revo uninstal and it's still doing the same result.
v12. old cable can use Active test.
v12 new cable can not auto detect vehicle, cannot connect to ECU.
Maybe I have a bad v2 cable?
Can you generate key for me?
Maybe old cable would work better for active test.
v14.20.19
D255586E49F4DC44937E8BA7021FBC01
Vehicle 1999 Lexus GS300
Thanks
881071
881072
881073
v14.20.19
Ver: 14.20.019
NA: c1105e00fc53791e416516bdb02d0d5250172001111906
EU: dd39bb1e37be91438a319c7ac6a27e1950172001111906
JP: 236fc13b04fe1900102011176c4fd76519b3bd4f068bc6
OT: ffea3f1fe3bff6e7d630e42e6b86017e50172001111906
