2101 - 2120 of 2169 Posts
please check post #2,084 there is a link there that includes techstream and its keygen which is perfect for your 2007
would that version also work on a 2019 Rav4 ? I have a 2007 Tundra i was hoping to remove the seatbelt chime and program a new key. I also wanted to remove the seatbelt chime in my parents 2019 Rav4.
no that version will not work for 2019 as that version works for cars upto 2016
here is the key
Software Version: 3954556B8E6BDA24311231C0698B1305
EU : b10e892e5579123b9bb26779a529b0ee50001912241700
JP : 73492afe6a2717012019240067d0b705fbfbaacd7310dd
NA : 01393d0b87b4232f84c1d93479e430a650001912241700
OT : ed953bcfa69c392661fc9143f351ec4850001912241700
here is the key
I'm so sorry for bothering you again, for some reason when I opened techstream now it is giving me a different software ID and wont accept the activation key.
Software ID: 0503A2AA111C982C558FF6C4E127F200
Software Version: 14.30.023
After doing some digging around I found out that the old Software ID still shows up when I run as administrator but the New Software ID shows up when I double click on Techstream. I'm still not sure which software ID I should be using. I also noticed that running as an administrator I'm having to keep reinputting the activation key every time I run the program. I believe I messed up and the correct Software ID I should have used was the Software ID: 0503A2AA111C982C558FF6C4E127F200
sorry for all the trouble again,
Your help is much appreciated,
Thank you,
Makaveli07
hope this will be useful
Ver: 14.30.023
NA: d8cc3a370361ebd546078f3711e97df450171912281948
EU: d4438ccafb10c67aa4679a52102863c450171912281948
JP: 76b095ecbb37190124192817581eb0851bccbd5f5a8796
OT: 9842f164e46ca659166051e441d6f51c50171912281948
Activation code works great thank you!, however, every time I start techstream it asks me to re-enter the activation code in order to use it; which is not a big deal, just wondering if this is this normal?
Thank you,
no its not normal also make sure to block techstream using firewall all instructions are included in this forum inorder to make things easy for everyone also "revo uninstaller" i used to uninstall the program and reinstall again to solve such issues
i just went through all the post made it easy for u so please check post beginning from #1,943 i believe someone had similar issue
I installed Techstream on windows 7. Could someone provide key for this
Version : 14.30.023
Thanks
Offical TechStream software thread( settings and such)UPDATED 1-31-2015
I updated my OP today 1/31/15
I have TechStream installed on 2 Pc's windows 8 or 7 non pro 64 bit. Im using cable MINI-VCI J2534 (Bought this when I originally posted this thread/Post in 06-26-2012
here is the work around link for windows 7/8 64 bit I did not update the firmware on the cable. I would leave yours alone.
http://www.ft86club.com/forums/showthread.php?p=1920724
Follow the Directions to a T and it works! big thanks to mendonsy and Robert_W and others.
Software Download link for TechStream version toyota-techstream-v9.30.002
https://www.dropbox.com/s/gl6r90tvw8uuee7/toyota-techstream-v9.30.002.zip?dl=0
Here are the 64 Bit drivers
https://www.dropbox.com/s/029qetxp67kg70z/Toyota Techstream V9.30.002.exe?dl=0
I did not intall or click on the Video guide(for 64bit)
Your antivirus software might come on and detect a trugan horse. I disabled it before I began. No problems that I can see by doing this. Do so at your own risk. 🤓
this seller has the cable and software
http://www.chinaobd2.com/
thanks
SP :D
I have Techstream software with the following ID, I need key for it, any help appreciated
3A50C34740365C5D12F5004497CAAB04
Version : 14.30.023
Ver: 14.20.019
NA: 8f4c4a42fa59907b99a65708c58d2b5d50171910130829
EU: f5db13e3d8be0d194c8c040cff4cc88b50171910130829
JP: 445c09c32931080102191317894d9c952afeaa5786ac89
OT: 83012b38af866bead8d300e54fc81d8850171910130829
Hello,
I installed Techstream and need key for it.
Version : 14.30.023
Thanks
All fixed and working now, time to buy a Fw 2.0.4 Mini VCI ! thank you very much!!
Version : 14.30.023
Version : 14.30.023
Thanks
you did not mention the year/make and type of the car you are trying to use techstream on??
p.s please check post #2,084 there is a link there that includes techstream and its keygen which is perfect for cars/trucks for the year upto 2016
Ver: 14.30.XXX
NA: 6654224db18f6535e5436b6c19f10e1b50251912301824
EU: d32d9ed3ed25c70ac9d6205d4116c63f50251912301824
JP: 3c9b0b6745c3180122193025fdd8b74516bfc974691e0b
OT: fdddbfb93df76e320ac991ab052fec1850251912301824
Hello @tdi200,
Would you please give me a key? Here is my info:
Software ID: F13023D8BD447D7BBA52B5587CD06B06
Version: 14.30.023
Vehicle: 2019 Toyota Tundra Double Cab SR5 4x4
Thank you and Happy New Year to you!
I need to take my stuff out of the package and use it soon too, a few things I would love to change.
not sure yet but you can give it a try and report back here but when you change region it will ask for keys again, but i have already given you the keys so based on region you select input that key given to u
Hello, could you provide me with key for Techstream with following ID
D953D3CEE33A432B8E8DB3AF803AE505
Version 14.30.023
Thanks
Version 14.30.023
Thanks
what year is your car that u are trying to use techstream on?
Version 14.30.023
EU : 260f0df8bab349c103f2a866455c14a350001912310735
JP : c03b362c6c8507012319310010626b5570d564c56558a5
NA : b2077bf9728cca8b75cc058b5c3cbd5250001912310735
OT : f722f69ddc41cc2a64fdf8e031f56db450001912310735
Hello @tdi200,
Version: 14.30.023
Version: 14.30.023
EU : f66aa3171db430763781f2b4d9cb90f450001912310733
JP : be8432617b460701231931007032c2356df2a503411723
NA : 93edffaf1f8c6212a37f4d0c9691122150001912310733
OT : 8547ed8a17ad8d7bb36dc112f7c6505c50001912310733
you are welcome and same to you
Version 14.30.023
Tank you. Have happy New Year
Guys if your car is bellow 2016 year please check post #2,084 the mega file consists of everything you ever need including keygen so u can run the software yourself to register techstream, anything after 2016 is okay to request keys we need to keep this forum neat as much as possible and also post #2,084 consists of all the drivers needs for the cable so please download that megafile regardless
