2041 - 2060 of 2435 Posts
OK, I used revo to uninstall, downloaded clean copies from your links and installed. Still the same problem:
I can talk to the computers in the vehicle, so maybe it's working and the error is just part of the deal?
Unable to view Live Data after "Offline Mode" message
Vehicle(s): All
Description: When a known good connection to the internet is active, Techstream will display a message with the option to continue in "Offline Mode". After selecting "Offline Mode" and selecing a desired system, the Live Data List for that system will fail to connect or lose communication shortly after ECU connection.
Status: Currently under investigation.
Workaround: Disable internet connection while viewing Live Data in Techstream.
i think its a known bug from v14 20 19
seen on this site: https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/tsrss/ts_known_bugs.html
Still working on my Reduced Functionality. Or the other - unable to connect to network, you have only 29 tries left, or something like that. I've now installed a completely clean XP from a Dell CD and I'll get to try that tonight. And I've ordered a Dell refurbished computer which should arrive within a week or so. It's frustrating as heck to try for so long with four versions of TS, playing with the settings, and never see Customization or Utility. I can usually see Data Lists, Live Engine data and do some Active Tests. Under Immobiliser, I can see Data List and turn the Security light on & off. Whoopee. Just can't make a key. I still wonder if it's the cable. I did that cable test under Help in TS and the results were not good. Sometimes I think I'll die behind the wheel of this Camry. But I won't be driving.
The new XP install was placed on a partition of the same drive as the other installs and it's given me a new Software ID. So, when you get a chance tid200, would you conjure up a key for me? Thank you.
V: 14.30.023
I have a 2006 Camry LE that I need to bleed the ABS module on. I have a mini vci v 1.4.x cable.
I set everything up and can see the solenoid active test modules but whenever I click utility--> air bleeding it says car not supported.
I also get the reduced functionality message.
Ver: 14.20.019
Can I get the keys? Hopefully having the keys will allow me to bleed the abs using techstream and mini vci 1.4.x.
Thank you in advance.
V: 14.30.023
Ver: 14.30.023
NA: 7a38e0feac39ad13481a435f50c408a950111912030602
EU: 1c8a535d9c9a2f3e4f41984c42650eb950111912030602
JP: adeec1b4f615060120190311bedc642545c813ea53c835
OT: e5fb9e17783fe1d2ed97985932457a0250111912030602
Version: 14.30.023
Thanks In Advance,
Ver: 14.30.023
NA: bd592f0580e87d4f1032e15dd14c1d9950111912030602
EU: 71d24e8e462360d1ca9d6585ffe1aaf950111912030602
JP: 42738bba6ff30601201903113cf555256954e26cc5e832
OT: e35c28cd89300d78bb8bb9361e5249dd50111912030602
Ver: 14.20.019
Ver: 14.20.019
NA: cf6d8fba23392627c64dc3c4fc4cbae550251912031311
EU: d6eb206227fd553d4371dba8a4b789e550251912031311
JP: a627d224350913012119032519544415a9e6d3818a299e
OT: b56bee8553d817f7f5f83e97f3f6a7f050251912031311
Ver: 14.20.019
Thank you so much!
quick update guys since i been busy with life and work have not got chance to mess around with the software specially about the reduced functionality error that is floating around.
so today upon searching i found a keygen for version 12 i suggest you guys to download version 12 from the link below and on the second link i will provide the techstream keygen
Techstream version 12.00.124: (02/2017) https://mega.nz/#!KJBRlQaC!WNKXptGws2SUeYnBw0N0zbkeA03EenPKFLr3_-l-e1k
Techstream keygen: https://mega.nz/#!CSgkyCQZ!SaGNv9VadBIpVGkgaTBlQyxa9td9Z7YLHX3psIlm-sU
keygen is self explanatory good for v7 to v12
it lets u pick the version you have the, only version i found was 12.00.124 if someone got 12.00.125 can use the keygen as well and see if it works again please give back feedback on the keygen and version 12
keygen is self explanatory please give back feedback on the keygen and version 12
Wow - thanks so much for this. I've just tried v13 and started looking for v12. I've read it has a good chance of working with my 2011 Camry. Thanks!
great please report back and make sure to use revo uninstaller to unistall techstream before downloading version 12
Installation went without error and it seems to work well. This is on an old XP laptop. At first, I thought it didn't require a code because it didn't ask for it until you hit Connect to Vehicle. I tried all four areas too - NA, Japan, Europe and Other. Keygen worked for all. I still can't program keys since I don't have Utility under Immobiser, just Fault Codes, Active Test (can only test security light), and Data List. And no Customization. No idea why. I'll try another cable. Another computer arrives next week with Windows 8.1. At least a couple of guys got it to work on a 2011 Camry so I'll keep at it. Thanks again.
That's strange hopefully we can figure outsomething. And with version 14 u had same issue?
Sent from my LG-H811 using Tapatalk
Yes, I've tried 12, 13 and several v14. I've checked other ecu's too since I saw a video where the key program was not under Immobiliser but under Main Body. But I see no Utility, Health Check or Customization anywhere. Just don't know if it's cable, software or computer problem Thanks.
