2001 - 2020 of 2190 Posts
Would someone be able to provide a key for me?
Software version 14.20.019
Software ID 310B9697DC2A5420741B5D0C46AF0705
Ver: 14.20.019
NA: 382b63ce59e00ef8b09951de3a7bbbc950251911211336
EU: 0e2f22413447c5737bd5cc0a4c2ae31a50251911211336
JP: 19d3a046ae28130113192125b0cb416535352129914fbe
OT: d63e79cd71a9e046043eee044de88e3e50251911211336
Ver: 14.20.019
Thank you sir!!
Have an awesome night!
Hi, need the keys for:
Ver: 14.00.018
Thanks!
Ver: 14.00.018
NA: 5fd7f9c588cc7d39065acd18a37a1c3950171911242300
EU: 07c338762b7cb05588fb5fbb54c017e250171911242300
JP: 6ce0a0c66551230110192417b621cd05a9573b0add309f
OT: 37944d25f56e841dab8aee133b36c71a50171911242300
I went back several pages, and there seems to be some variance in cables. What works for V14.00.18 and an 07 Sequoia? I see some with firmware v1.4.1 and some with v2.0.4. thanks!
Thanks tdi200! I have the latest version downloaded and installed, new cable is ordered and on the way. New version gave me the same ID as before, but the key doesn't work. I'll need a new key:
ver: 14.30.023
ver: 14.30.023
EU : 7d10ee3ff8503d706452a78299aa68d450001911250742
JP : b8b1177c0ac80701141925004fa1a325245ab45797f655
NA : b717e6c3e2ac2e8d1883569a5f60d24050001911250742
OT : e103a92d71b26ee81842aeee53b3725650001911250742
Hi tdi200 - I've been on toyotanation for the past few days since I acquired a 2011 Camry LE but luckily found you here. I'm getting that "reduced functionality" message too and some tabs are missing. I can't even find how to program a key. I looked under "immobilser" "main body" and can't find anything. I think I'm looking for "Utility"? Can't access "theft deterrent". Anyway, I'll keep fooling with it but I wanted to ask for a key if I may. I think it would be better than the Techstream patch shortcut I'm using now. Thank you!
V.: 14.20.019
V.: 14.20.019
hi there i am also a toyotanation member with the same username and i own a 2014 camry
here are the keys if you still have reduced functionality that i suggest u to download "revo uninstaller" and use that to completely uninstall the program and than install a newest version which is this: https://mega.nz/#!WRRngabS!ScZL5GbvMrVV_SHwRIstv9ug8WXV9UNRqWytdEbsPzg and i will provide the keys
Ver: 14.20.019
NA: 464521786e33ac075b81dd1ff8c6882950111911270945
EU: eca8452df497cd143ca8b172830e483c50111911270945
JP: d2634063930509011419271176561b555569c1a39fe1b1
OT: 4bb362952fcaa8687eaf7f3bcab5d27450111911270945
Update, I was able to program the remotes even with reduced functionality. Just that was worth the price of the cable. yay!
thanks again tdi200!
I have my cable now, tried to connect and am also getting "reduced functionality". It's talking to the car, but all the computers come up yellow. Will try removing and installing again.
I just followed tdi200's advice and used revo uninstaller. It seems that it uninstalled the vci driver along with techstream which is good I think. Then installed v14.3, then the 32 bit driver - I have an old Dell 610 with XP Pro sp3. I won't know until tonight if it works or not. I'll post back.
Ver: 14.20.019
I did as you suggested but got the key from the cable seller. It works and shows nearly 5000 days but is there a way to avoid entering the key each time the program is opened?
area of confusion,
u got the key from the seller? is that for V14.30.023?
why are u using win xp 32bit? here are the drivers for 64bit: https://mega.nz/#!XORUGALJ!_hghYOjdiVF-hLL6DQXL6kVGNGb5qfdzsCJenGjv5PY
note installing the drivers means its tweaking the registry so its highly recoomended to turn off ur antivirus as well
i got no idea why u have to input the key every time u launch the program could be because the program is not taking the key and did u block techstream to access the internet using firewall if not that could be an issue too?
i highly suggest u do to download v14.30.023 from the link i provided and provide me with software id and i can get u the keys.
Using xp on an old laptop - it's the only one I have and it's standalone, no internet, no security software. It seems to take the key since the 5000 day expiration shows up but maybe not. Yes, for 14.3.023. Could I try your key using the same ID 01AF5230FC4B9E848F601CD3CD348802 and software v14.3? Maybe I can avoid an uninstall. Thanks.
its really confusing why some of u guys getting the reduced functionality i might have to use teamviewer to see it for myself but at this point all i can think is of uninstalling the program using revo and deleting everything associated with teamviewer and start over again.
as everyone giving me their keys but they dont tell me where did they install the program from? if the program came from en ebay seller that u already installed its clearly not a "clean install" should be clean untouched install
Just FYI: I'm using a laptop running windows 10 64 bit. I used the driver supplied by the cable (aidixun), but the techstream/key supplied by tdi200. Cable is supposed have firmware 2.0.4.
