Im planning on getting some off road lights and a light bar. Im not very good with wiring so is the off road lights a simple install? If anyone has a step by step that would be great Thanks
I put a fuse holder on the wires, I bypassed the hi/low ignition though so I can turn them on by themselves.That helps what fuse panel do you run to? under the hood or in the cab?
Well the 25 amp fuse is for 2 lights or two wires of 14 gauge each. Plus I was just using the supplied KC light harness with some added wire to run it to the back of the truck. The 14 gauge wire is thicker than the supplied wiring in the KC harness. But I will see about putting a smaller fuse in there if you after you read this you think I need to.25 amps is too big for a 14 gauge wire. Fuses protect the light and the wire. The wire could catch fire before the fuse blows. 14 gauge should be a 15 amp fuse. I would suggest adding a smaller fuse for each of your 14 gauge runs. 25 amp fuse would need a 10 gauge wire.
Yes, I really do think so. I get that 25 amps is enough for all the wires together, but you need to think of them as individual wires. All it takes is for one of those wires to partially short or something happen with the light and draw enough power to melt the 14 gauge wire and start a fire. You want the fuse to blow before the wire melts and starts a fire.Well the 25 amp fuse is for 2 lights or two wires of 14 gauge each. Plus I was just using the supplied KC light harness with some added wire to run it to the back of the truck. The 14 gauge wire is thicker than the supplied wiring in the KC harness. But I will see about putting a smaller fuse in there if you after you read this you think I need to.
