I have a 2002 Toyota Tundra access cab SR5 with the TRD package. On Sunday the check engine light came on because bank 1 sensor 2, went bad. I looked around and found that it was the drivers side sensor behind the cat. I went to replace it last night but the nuts are completely rusted away. I disconnected the negative terminal on the battery before I climbed under the truck so it reset the check engine light.
I drove around the block last night and it seemed fine so I parked it for the night. This morning it was fine until the motor warmed up, now it stalls at idle. I'm assuming its because the bad sensor is still on there and the check engine light is no longer on.
Is this a reasonable assumption? Will unplugging the sensor force the CEL to come back on so I can make it to a garage?
Thanks,
Alec
Thanks,
Alec
