1 - 20 of 30 Posts
Super easy mod. Bought the voltmeter for 12.99 and the dual 2.l usb charger for 12.99 on Amazon. Removed oem dual cig lighter ports. Over drilled slightly and installed the voltmeter in one and the usb in the other utilizing the existing red/wht wiring since it's already fused. Took 30-min!
Gee, other than NO voltmeter, I have no clue what I even have there on that panel, lol :eek:
Reactions: Wacked
nice! solid, useful mods.
Cool mods. Just curious on the voltmeter - Do you not have a factory volt gauge or is this to provide a more accurate reading?
Reactions: Wacked
nice mod. I would like to run a REAL 15amp fuse and rated wire to replace the laughable wiring they have behind there 12v outlets and the outlets themselves. I have pubic hair that's thicker. :yikes:
Reactions: Wacked
Trans-Immigrant
i ran a solid wire from my distribution block to behind the center console. I have an anderson plug so i can swap out different plugs. I usually use that for my fridge or oven, but can also swap in a cigarette plug. much nicer knowing its a heavy duty cable and nothings going to burn out.
nice! i just saw your rig. Nice. Thats how you use a truck baby. You have to admit the OEM wiring is a joke. I could not even run a 100wat modified sine wave inverter off it.
Reactions: Dragos28
Discussion Starter #9
Just. Little more accurate. I have a aftermarket amp and sub. Plus is was only $12
Reactions: Wacked
Links on Amazon? Great Mod!
Reactions: Wacked
Discussion Starter #11
Nice work! I connected mine to a switch so I can charge while the truck is off!
Yeah ALL trucks should have at least one outlet that's always on from the factory
My wife's MKC has the outlets hot all the time.
It also turns them off at a certain voltage to avoid draining the battery and not being able to start.
Discussion Starter #17
Where did you get your lightbar switch that fits in oem blank?
Reactions: Wacked
Discussion Starter #20
Reactions: Wacked
1 - 20 of 30 Posts
