Just installed some 18x9 +18mm Raceline Shift wheels on some 285/70/18 Nitto Exo Grapplers.
The wheels are labeled as dark tint, but they have a goldish/bronze look to them. The front wheels actually rubbed (minimal) the caliper due to the wheel barrel having some type of raised section. I had to grind a little bit of the caliper (maybe 1-2 mm at most) to give it enough clearance.
The tires do hum on the road but nothing like a M/T. I've read some reviews and most say that they wear good. They are 33.98" tall and 11.5" wide. I had to push the front wheel liner forward. I was able to keep the rear mud flap with the help of some bending and drilling of new hole. This is with a 3 inch front lift only. Stock rear.
These pics are were taken with 1.25" wheel adapters because of the rubbing issue. They did rub like crazy too.
