Hey guys picked up a 2013 white tundra CM 2wd and need help deciding how to lift it...I want to run 35 toyo mts with 20x10 monsters (-12 offset), I'm thinking maybe 3.5 cst spindles with 3' spacer (truxx) and 3' block in the back for most cost effective setup, or replacing the 3' spacer with Kore fox 2.5 coilovers (way more $$$) or just going with a 6 procomp or bds lift to make it easy...any insight or adivice guys?? Thanks
"Seahawks Hater"
I got a 3 block in the back and it's horrible. I would really try to avoid that. Coach builder is a member here that makes shackles that will give you lift without sacrificing the rear crappy drive with blocks. I would do the spindle and spacer lift, will save a lot of money over the others. You gotta be careful as you might need new uca,s because of the angles. I have a 6 inch pro comp bracket lift and didn't need them though.
