1 - 8 of 8 Posts
Just picked up a TRD pro in cement after totaling my SRF TRD Off Road (which I had lifted and G2 Terra Grapplers on)
Love this truck and my old SR5.
So I ordered the Ready Fit 2" lift and some Terra Grapplers in 25x12.5x18" running the stock rims any one have any trouble with this size causing driving issues, shifting, etc?
Everything is wrong with that.
Cancel the lift, it will just screw everything up. You already have a very nice suspension with 2" lift over other Tundras. 35x12.5 are too wide for stock rims and offset. If you want to use stock rims and offset, 285/75r18 or 295/70r18 will usually work. You could also add 1" or 1.25" spacers for a wider stance. Expect to remove mudflaps and deal with some fender plastic.
If you really want 35x12.5, then get new 9" wide wheels with +25 to +35mm offset.
Yes I have the pro. I saw ready lift made a lift specifically for the pro /sst which is why I started there.
Appreciate your advice guys. Going to rethink what I am doing.
On my sr5 trd off road I had a procomp 3"/1" leveling kit and 305 65 18 terra grapplers. I loved the look and stance and was trying to mimic that with the pro.
Did you have stock rims? No spacers?
305/65r18s are 33.6" dia, so smaller than 295/70s (~34.2") and 35s (~34.6").
You don't need a lift for the Pro for any of these, just leave it be.
I have a 17 cement pro dc. I have the readylift +2 up front which works great. It's a spacer and uca up front but not a junk quality spacer. It replaces the factory top hat completely and is very solid. I ditched the block for the back and went with Dakar leaf springs and extra leaf pack so the rear is approx 2.5-3" of lift which almost doesn't look raked. I can't promise you will fit 35x12.50 but if you wanted to try with the stock rims you will need wheel spacers. I threw 1.5 spider tracks on mine with the front lift and the wheels sit just barely out from stock as the lift sucks the hub in slightly. I haven't throw new rubber on yet but I'm looking at 295/70r18's which is roughly 34-34.5" x 12". I know they will clear just fine with the skid plate on. I'll upload a pic after I get home.
1 - 8 of 8 Posts
