The u joint inside the cab of the truck is probably bindingHello so I just got a 2003 tundra and had ti install an new rack and pinion and new power steering pump but I’ve bleed the system for over an hour and it is still hard to turn. Any suggestions would be appreciated
That's what happened with mine. I thought I needed a rack till I looked more at it and realized the joint was all rusted upThe u joint inside the cab of the truck is probably binding
spray with pb blaster real good then with a lubricant
had that wrong with my truck also a 2003
