So I'm busy installing a 3.5" IronMan Foam Cell Pro Lift, and I cannot for the life of me get the front coil-overs to line up. As you can see from the photos, I have the 4 top bolts lined up but the bottom mount is cockeyed from the orientation where it needs to be. Photo is of the passenger side, but it was a very similar situation on the driver side. I don't want to just excess force it in there with a mallet because that would destroy the finish of both the shock and the LCA and expose both of them to Minnesota Salt and cause them to rust much more quickly.
Has anyone else had this happen? Is there a good way to re-align the bottom shock hole? If I just shove a screwdriver in there and try to twist it, will it damage anything? I've installed a lift kit before on a 4runner and didn't have this issue, but this is still only my second lift install ever so could be something really simple that I'm overlooking. Any help or tips would be appreciated on this.
