1 - 14 of 14 Posts
About 9 months ago I had a shop do the 5100 @ mid setting with two CB shims along with a 34" wheel and tire upsize.
I always suspected the alignment was not done right but the shop told me it was good. It drove fine. I kept an eye on the tire wear and after my last tire rotation I didn't like the wear, so I took it to a off road specialist and had an alignment done. The truck drove noticeably better, I ran the numbers by our resident experts and they said they were spot on. However its been about a month now and I just started noticing a click or knock in the front suspension from time to time at near full lock? That never happened before.
Before I go back to the alignment guys can somebody help me understand what that sound may be?
Thanks
It does it so rarely that I just let it go. It almost always makes a sound when I pull the trailor. But that is maybe once a month.
Honestly I think the Bilstein 5100s with the CB shims was the wrong way to go. If I could do it all over again I would go spindles for sure.
Could you be just hitting the factory steer stop?
Pretty sure this has been brought up by others in the past.
You might want to make sure the eccentric bolts on the lower control arm are torqued correctly. When I had my 5100s installed at a 4x4 shop they didn't torque them enough and I would get a popping sound in the front suspension. They need to be 205 foot pounds I believe.
Reactions: Skiddy
I dont think so because it has made that sound without turning.
But who knows Im not a mechanic?
Discussion Starter · #11 ·
Mine is 4x2
Sent from my iPhone using Tapatalk Pro
Same here 4x2
Suspension shops here in the Tampabay area are very lacking. They should just call themselves leveling shops.
What Id give for a local reputable Suspension shop.
Same here 4x2
It still drives fine. Hopefully the rack and pinion is still fine . I've stopped coming to suspension shop since they put 100ft/lbs for the Lower control arm after installing 6112 I start doing the work myself.
Found this. The sleeve looks oval. This is the steering rack bushing. Not sure if this causes the popping noise while turning. My truck just got 30000 miles.
1 - 14 of 14 Posts
