I get a pretty awful shimmy in the truck when braking downhill in these big mountains passes here. Also get it when towing. I don't really notice it too much in town but I live in a smaller town and only drive short distances. Spoke with the dealership yesterday and they are aware of the TSB for the brake backing cooler plates or whatever you call them. I will have those placed on the truck but was wondering if I should turn the rotors or replace them all together? I have 49K miles on the truck and run some pretty large tires, 34's. I spend a lot of time in the dirt as well. If you would recommend new rotors, would you give me some brands that are good? I assume I want non slotted or drilled since I am in the dirt so much, right? However, the issue with the tundra brakes is that they heat up and warp so maybei should go with the drilled ones, dont know. But if just turning them will work, should I go that route? I can replace them myself, i just dont know which is better at this stage.
Also if you want to comment on pads, that would be cool.
Thanks Tundratalk
Thanks Tundratalk
