1 - 9 of 9 Posts
I swapped out brake lines with stainless steel, slapped on cryo-slotted rotors, Hawk pads and was super impressed with improved stopping. Definitely worked best for my 2008 Tundra from what I've previously tried.
2008 Tundra Limited Crew Cab
You will get a Ton of opinions and recommendations which is good I guess. You can pick and choose what you want to use. I will say this……. A Brake mechanic told me the stock rotors will tend to heat up and warp fairly shortly in their life-cycle which causes steering wheel shake later. I installed Brembo Rotors (not the most expensive- not drilled) and it was like I had a new brake system. I can’t imagine how nice it would with other high-end improvements.
Get Brembo Rotors,
Eddie
2012 CM SR5 5.7L 4WD
I came here as well for opinions on brakes when I did a complete all around brake job on my truck almost this time last year. I ended up choosing the power stop truck and tow kit/series for my 2012 crewmax and could not be happier. Yes they have the drillled and slotted rotors. I was talking to my neighbor who is a certified Toyota master mechanic and he recommended keeping the runner brake lines as I was considering swapping out for the SS as well from powerstop. As previously mentioned you will get all different answers but I have been a happy camper. You can find the PS on Amazon or at summit racing and I actually found the kit the cheapest at rock auto. Better than giving Bezos more bucks. Oh and the red calipers look great 👍🏻.
Reactions: Chilledman
I fully agree.
And embed properly for best results, longest life.
AKEBONO PERFORMANCE ULTRA PREMIUM CERAMIC DISC BRAKE PAD KIT is top notch.
Made in USA
1 - 9 of 9 Posts
